Einleitung
We will teach you how to successfully take apart the phone system to do any repairs and be able to fully but it back together.
Was du brauchst
Unplug the phone from the base by detaching the RJ-11 plug.
Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
Using the spudger, separate the top shell of the base from the bottom shell from the base.
Unscrew the 3 screws (Head Size: 4mm Length: 8.6 mm) from the top shell circuit board.
Unscrew the 2 screws (Head Size: 4mm Length: 8.66) on the small circuit board in the top shell.
Release the speaker from the locking pin by pushing down on each ending side of the pin and pushing it away from the speaker.
The disassembly of the phone base is complete!
Now this guide will move on to taking apart one of the handsets.
Remove the battery, and unscrew the two screws (Head Size: 4mm Length: 8.6 mm).
Unscrew the two screws (Head Size: 4mm Length: 8.6mm) on the bottom shell keeping the speaker locking pin in place.
