Zum Hauptinhalt wechseln
Uniden EXP 371 Antenna Replacement
Was du brauchst
  1. Uniden EXP 371 Antenna Replacement, Uniden EXP 371 Teardown: Schritt 1, Bild 1 von 1
    • Uniden EXP371 900 MHz Cordless Phone.
    • 900 MHz Extended Range with One Touch RocketDial/Find Handset Locator and is Desk or Wall Mountable.
  2. Uniden EXP 371 Antenna Replacement: Schritt 2, Bild 1 von 2 Uniden EXP 371 Antenna Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery by first pressing down on the rear of the cover and pushing the cover towards the bottom of the phone.
    • Next remove the battery by pulling on the connector.
  3. Uniden EXP 371 Antenna Replacement: Schritt 3, Bild 1 von 2 Uniden EXP 371 Antenna Replacement: Schritt 3, Bild 2 von 2
    • Next remove the two screws at the bottom of the phone with a PH1 philips screwdriver.
    • Now remove the top portion of the case from the bottom. This may be difficult to do with your bare hands. The use of a plastic opening tool may come in handy.
  4. Uniden EXP 371 Antenna Replacement: Schritt 4, Bild 1 von 3 Uniden EXP 371 Antenna Replacement: Schritt 4, Bild 2 von 3 Uniden EXP 371 Antenna Replacement: Schritt 4, Bild 3 von 3
    • Your next step is to remove the five screws holding down the motherboard. Use the PH1 philips screwdriver.
    • Once you have removed the five screws you may lift the motherboard off of the front case.
    • At this point you may also remove the dial pad. It simply lifts off.
    • You may also remove the speaker if needed by unscrewing the two screws using the PH1 philips screwdriver.
    • The whole phone is now disassembled at this point.
  5. Uniden EXP 371 Antenna Replacement, Antenna: Schritt 5, Bild 1 von 2 Uniden EXP 371 Antenna Replacement, Antenna: Schritt 5, Bild 2 von 2
    • After following the teardown guide. Take the bottom case and locate the antenna at the top of the phone.
    • Lift the bottom of the the antenna with the aid of a tool (these tweezers work well) and push the antenna inside the phone to remove it.
    • To reassemble the phone, follow the steps in the reverse order.
Abschluss
Eric Rodrigues
343 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Mitglied von UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,257
