Zum Hauptinhalt wechseln
Uniden EXP 371 Keypad Replacement
Was du brauchst
  1. Uniden EXP 371 Keypad Replacement, Dissassemble the Uniden EXP 371 phone: Schritt 1, Bild 1 von 1
    • Refer to the Uniden EXP 371 phone disassembly guide to open the plastic casing.
  2. Uniden EXP 371 Keypad Replacement: Schritt 2, Bild 1 von 3 Uniden EXP 371 Keypad Replacement: Schritt 2, Bild 2 von 3 Uniden EXP 371 Keypad Replacement: Schritt 2, Bild 3 von 3
    • Use the Phillips #1 screwdriver to unscrew the screws located at the bottom left and right hand corners and top of the phone; as shown in the image.
  3. Uniden EXP 371 Keypad Replacement: Schritt 3, Bild 1 von 2 Uniden EXP 371 Keypad Replacement: Schritt 3, Bild 2 von 2
    • Remove the motherboard once the screws holding it in place are undone.
    • Once the motherboard has been removed, remove the rubber button pad located behind the motherboard and in front of the dial pad.
  4. Uniden EXP 371 Keypad Replacement: Schritt 4, Bild 1 von 1
    • After the rubber pad is removed remove the dial pad (buttons) from the phone.
  5. Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: Schritt 5, Bild 1 von 2 Uniden EXP 371 Keypad Replacement, [OPTIONAL ] Soak dial pad in mixture of soap and water: Schritt 5, Bild 2 von 2
    • If the buttons are sticky; leaving the dial pad and/or rubber pad to soak in soap and water for 5-10 minutes will clean off any sticky residue that may be obstructing the buttons.
    • Make sure to properly dry the dial pad and rubber pad of any soap/water before reattaching them to the phone to avoid the risk of short circuiting.
  6. Uniden EXP 371 Keypad Replacement, Order a New Dial Pad: Schritt 6, Bild 1 von 1
Abschluss
Lucas Mohsen
101 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 2-1, Duarte Fall 2014 Mitglied von UMass Dartmouth, Team 2-1, Duarte Fall 2014
UMASSD-DUARTE-F14S2G1
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 140
