Zum Hauptinhalt wechseln
Uniden TCX905 Circuit Board Replacement
Was du brauchst
  1. Uniden TCX905 Circuit Board Replacement, Battery Cover: Schritt 1, Bild 1 von 2 Uniden TCX905 Circuit Board Replacement, Battery Cover: Schritt 1, Bild 2 von 2
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
  2. Uniden TCX905 Circuit Board Replacement, Battery Pack: Schritt 2, Bild 1 von 2 Uniden TCX905 Circuit Board Replacement, Battery Pack: Schritt 2, Bild 2 von 2
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
  3. Uniden TCX905 Circuit Board Replacement, Back Shell: Schritt 3, Bild 1 von 2 Uniden TCX905 Circuit Board Replacement, Back Shell: Schritt 3, Bild 2 von 2
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
  4. Uniden TCX905 Circuit Board Replacement: Schritt 4, Bild 1 von 3 Uniden TCX905 Circuit Board Replacement: Schritt 4, Bild 2 von 3 Uniden TCX905 Circuit Board Replacement: Schritt 4, Bild 3 von 3
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
  5. Uniden TCX905 Circuit Board Replacement: Schritt 5, Bild 1 von 3 Uniden TCX905 Circuit Board Replacement: Schritt 5, Bild 2 von 3 Uniden TCX905 Circuit Board Replacement: Schritt 5, Bild 3 von 3
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
  6. Uniden TCX905 Circuit Board Replacement, Circuit Board: Schritt 6, Bild 1 von 2 Uniden TCX905 Circuit Board Replacement, Circuit Board: Schritt 6, Bild 2 von 2
    • Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
  7. Uniden TCX905 Circuit Board Replacement: Schritt 7, Bild 1 von 3 Uniden TCX905 Circuit Board Replacement: Schritt 7, Bild 2 von 3 Uniden TCX905 Circuit Board Replacement: Schritt 7, Bild 3 von 3
    • Using index finger and thumb, carefully remove the circuit board from the front shell of phone
Abschluss
Gary Pence
807 Reputation
8 Anleitungen geschrieben
Clemson, Team 1-1, Benson Spring 2014 Mitglied von Clemson, Team 1-1, Benson Spring 2014
CLEM-BENSON-S14S1G1
3 Mitglieder
16 Anleitungen geschrieben
2 Kommentare
I liveI at Buenos Aires, Argentina. I need to repaire a Uniden TCX905 Circuit Board and I wish to receive the manual for repaire, if it existe. Thanks in advance . Ruben E. (zrubene@gmail.com)
zrubene - Antwort
Where can one get a TCX905 replacement circuit board?
greywing - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 892
