Einleitung
The home button is located in the center of the front side of the phone, just underneath the screen.
Was du brauchst
Starting from the top of the cover, slide down and away from the phone with your thumb
Lift battery cover off of batter and place it to the side
Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
Place battery pack to the side
Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
Ensure that wired connection between circuit board and back shell is not strained
Fold the back shell underneath the front shell and circuit board
Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
Using index finger and thumb, carefully remove the circuit board from the front shell of phone
Remove the white plastic sheet covering the silicon button pad
Remove the silicon button pad to access the home button and spring
Once the silicon button pad is removed, remove the spring from home button
Finally, remove the home button from its setting in the front shell of the phone
