Einleitung
This guide will explain how to replace the camera in this tablet. If there is any confusion about removing the battery, see the battery replacement guide.
Was du brauchst
Undo the clips off the power ribbon connecting the camera to the motherboard using the blue pry tool.
Use the pry tool to remove the yellow tape from the power ribbon connected to the camera.
Place the plastic pry tool under the camera component and lift it off the tablet.
