Zum Hauptinhalt wechseln
Uniden UTAB71 Camera Replacement
Was du brauchst
  1. Uniden UTAB71 Camera Replacement, Camera: Schritt 1, Bild 1 von 2 Uniden UTAB71 Camera Replacement, Camera: Schritt 1, Bild 2 von 2
    • Use a plastic pry tool to separate the two halves of the tablet.
    • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
    • Make sure the tablet is powered off before prying open.
    • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
  2. Uniden UTAB71 Camera Replacement: Schritt 2, Bild 1 von 2 Uniden UTAB71 Camera Replacement: Schritt 2, Bild 2 von 2
    • Use a credit card to lift the battery off the back of the tablet.
    • Do not put any pressure on the motherboard or any other internal components.
    • The battery is glued onto the back of the tablet so make sure to apply as much pressure as needed
  3. Uniden UTAB71 Camera Replacement: Schritt 3, Bild 1 von 1
    • Undo the clips off the power ribbon connecting the camera to the motherboard using the blue pry tool.
  4. Uniden UTAB71 Camera Replacement: Schritt 4, Bild 1 von 3 Uniden UTAB71 Camera Replacement: Schritt 4, Bild 2 von 3 Uniden UTAB71 Camera Replacement: Schritt 4, Bild 3 von 3
    • Use the pry tool to remove the yellow tape from the power ribbon connected to the camera.
    • Place the plastic pry tool under the camera component and lift it off the tablet.
Abschluss
Ryan Jewell
422 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 5-4, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 174
