Zum Hauptinhalt wechseln
Einleitung
In this guide, you will learn how to uninstall programs from your HTC Fortress.
  1. With the phone powered on and at the home screen, tap "Start".
    • With the phone powered on and at the home screen, tap "Start".
  2. Tap "Settings".
    • Tap "Settings".
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Tap "System".
    • Tap "System".
  5. Tap "Remove Programs".
    • Tap "Remove Programs".
  6. Your installed applications will be listed here. Simply highlight the application you want to remove and tap "Remove".
    • Your installed applications will be listed here. Simply highlight the application you want to remove and tap "Remove".
Abschluss
The application will now be uninstalled from your phone.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Lucas David
501 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 4-13, Maness Spring 2013 Mitglied von Cal Poly, Team 4-13, Maness Spring 2013
CPSU-MANESS-S13S4G13
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 537
