Was du brauchst
When your triggers get stickier than the Cheeto® dust on your hands it might be time for an intervention.
Start off by removing the four TR9 Torx Security screws on the back of the controller.
The two screws on the top are further inset than the others. You can use the iFixit 1/4" to 4 mm Driver Adapter as an extender.
Apply a gentle twisting motion to separate the first clip.
Twist in the other direction to separate the second clip.
The top is now free!
Here's our problem, the rubber pad has fallen off of the plastic stop leaving only the glue behind.
The rubber pad should still be in the controller somewhere (happy hunting) or if you're not in the mood for hide and seek any kind of foam will work as a replacement.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Great, concise fix instructions!
My nimbus started to have sticky triggers. I could not believe that I had found this solution! Awesome!
Hi, I have a Nimbus + controller. It's seems to have clips at the back too. Any advice on how to open it?
Greetings, someone who can help me where I can get the joystick, original remote control ?
Excellent information
