Zum Hauptinhalt wechseln
Unsticking SteelSeries Nimbus Triggers
Was du brauchst
  1. Unsticking SteelSeries Nimbus Triggers, Unsticking SteelSeries Nimbus Triggers: Schritt 1, Bild 1 von 1
    • When your triggers get stickier than the Cheeto® dust on your hands it might be time for an intervention.
  2. Unsticking SteelSeries Nimbus Triggers: Schritt 2, Bild 1 von 2 Unsticking SteelSeries Nimbus Triggers: Schritt 2, Bild 2 von 2
    • Start off by removing the four TR9 Torx Security screws on the back of the controller.
  3. Unsticking SteelSeries Nimbus Triggers: Schritt 3, Bild 1 von 3 Unsticking SteelSeries Nimbus Triggers: Schritt 3, Bild 2 von 3 Unsticking SteelSeries Nimbus Triggers: Schritt 3, Bild 3 von 3
    • The two screws on the top are further inset than the others. You can use the iFixit 1/4" to 4 mm Driver Adapter as an extender.
  4. Unsticking SteelSeries Nimbus Triggers: Schritt 4, Bild 1 von 2 Unsticking SteelSeries Nimbus Triggers: Schritt 4, Bild 2 von 2
    • The case is now open, but it's still held together by two clips on the top.
  5. Unsticking SteelSeries Nimbus Triggers: Schritt 5, Bild 1 von 3 Unsticking SteelSeries Nimbus Triggers: Schritt 5, Bild 2 von 3 Unsticking SteelSeries Nimbus Triggers: Schritt 5, Bild 3 von 3
    • Apply a gentle twisting motion to separate the first clip.
    • Twist in the other direction to separate the second clip.
    • The top is now free!
  6. Unsticking SteelSeries Nimbus Triggers: Schritt 6, Bild 1 von 3 Unsticking SteelSeries Nimbus Triggers: Schritt 6, Bild 2 von 3 Unsticking SteelSeries Nimbus Triggers: Schritt 6, Bild 3 von 3
    • Be mindful of the three cables still connecting the two halves.
  7. Unsticking SteelSeries Nimbus Triggers: Schritt 7, Bild 1 von 2 Unsticking SteelSeries Nimbus Triggers: Schritt 7, Bild 2 von 2
    • Here's our problem, the rubber pad has fallen off of the plastic stop leaving only the glue behind.
    • The rubber pad should still be in the controller somewhere (happy hunting) or if you're not in the mood for hide and seek any kind of foam will work as a replacement.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Jonathan
464 Reputation
2 Anleitungen geschrieben
4 Kommentare
Great, concise fix instructions!
Brian Pippen - Antwort
My nimbus started to have sticky triggers. I could not believe that I had found this solution! Awesome!
Max-Heinrich Laves - Antwort
Hi, I have a Nimbus + controller. It's seems to have clips at the back too. Any advice on how to open it?
Sean Hudson - Antwort
Greetings, someone who can help me where I can get the joystick, original remote control ?
Excellent information
bryan Andino - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 32
Insgesamt: 6,094
