Zum Hauptinhalt wechseln
Untracked Bifold Door Pin Replacement
Was du brauchst
  1. Untracked Bifold Door Pin Replacement, Bifold Door Pin: Schritt 1, Bild 1 von 1
    • Stand on a small ladder or step stool to get a better view of the top of the door.
  2. Untracked Bifold Door Pin Replacement: Schritt 2, Bild 1 von 1
    • Locate the pin at the top of the door.
  3. Untracked Bifold Door Pin Replacement: Schritt 3, Bild 1 von 1
    • Remove the current pin with pliers.
  4. Untracked Bifold Door Pin Replacement: Schritt 4, Bild 1 von 2 Untracked Bifold Door Pin Replacement: Schritt 4, Bild 2 von 2
    • Clean the top of the door using cleaning spray and a rag. This will help remove any dust or wood fragments left behind.
    • I used Meyer's spray, but any household cleaning spray will work just fine.
  5. Untracked Bifold Door Pin Replacement: Schritt 5, Bild 1 von 1
    • Replace old pin with new pin using the pliers to place into the hole at the top of the door.
    • You can purchase a new pin at either Ace Hardware or Home Depot.
  6. Untracked Bifold Door Pin Replacement: Schritt 6, Bild 1 von 1
    • Push the pin all the way in by using a hammer.
    • No excessive force is needed. Gently tap the pin with the hammer until it is secured.
  7. Untracked Bifold Door Pin Replacement: Schritt 7, Bild 1 von 1
    • Line up the newly placed pin with the door's tracking.
    • Push the door down slightly and then lift it back up to align it with the track.
  8. Untracked Bifold Door Pin Replacement: Schritt 8, Bild 1 von 1
    • Secure the pin within the tracking using the pliers.
  9. Untracked Bifold Door Pin Replacement: Schritt 9, Bild 1 von 1
    • When completed, the bifold doors should close and be positioned within the tracking.
Abschluss
Catelyn Carpenter
169 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 12
Letzte 30 Tage: 42
Insgesamt: 1,485
