Einleitung
Upgrade up to 16 GB of RAM memory in your 21.5" iMac
All photos are property of iFixit
Was du brauchst
First you need to remove the glue from the edge of the iMac
Use a Guitar Pick around the screen to remove the glue
Once you are sure the adhesive is removed, use two heavy suction cups to lift the screen
Unplug these cables:
DisplayPort Cable
Power Cable
Lift the screen from the iMac
Remove the four Torx T10 screws
Unplug the SATA cables and remove the hard drive
Remove these 3 Torx T10 screws
After you remove the screws, remove these cables
Fan Cable
Unstick and unplug the camera cable
Remove these 2 Torx T10 screws
Unplug these 2 cables
Unplug 2 more cable below the power board by pressing the clip
Unplug these 4 antenna connectors
After that, remove these two Torx T10 screws
Move the speaker and unplug the cable from the logic board
Remove these other cables
For finish, remove these four Torx T10 screws
Unscrew 3 Torx T8 screws from the heatsink, then remove the logic board from the iMac
Flip the logic board over and release the tabs from each side of the RAM
To reassemble your device, follow these instructions in reverse order remembering to re-glue the screen.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
