Was du brauchst
Open the latch on the right side that secures the battery in place.
Open the latch on the left side that secures the battery in place.
Now remove the battery.
Using a Philips-head screwdriver remove highlighted screws.
Look at the marking to see how to remove the access cover.
Remove the access cover as shown by the marker.
This is where you'll find the PCIe SSD.
Remove the fastening screw with the Philips-head screwdriver.
Remove the PCIe SSD.
To put the device back together, follow the steps in reverse order.
100%
Alex Niculescu hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Hier starten ›
