Ersatzteile
Kein Ersatzteil erforderlich.
  1. Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse
  2. Use the Phillips #1 screwdriver to unscrew the six round head screws on the bottom of the mouse. Those marked with squares are 9 mm in length, the rest are 5 mm in length. Use the Phillips #1 screwdriver to unscrew the six round head screws on the bottom of the mouse. Those marked with squares are 9 mm in length, the rest are 5 mm in length.
    • Use the Phillips #1 screwdriver to unscrew the six round head screws on the bottom of the mouse. Those marked with squares are 9 mm in length, the rest are 5 mm in length.
  3. Grab the top shell of the mouse and lift up to remove. Grab the top shell of the mouse and lift up to remove. Grab the top shell of the mouse and lift up to remove.
    • Grab the top shell of the mouse and lift up to remove.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. The capacitors on this board can release stored electrical energy if touched.
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  6. To remove the white wire connector on the bottom board, use a spudger underneath the white plug and pop it out (this disconnects the upper board from the lower board). To remove the white wire connector on the bottom board, use a spudger underneath the white plug and pop it out (this disconnects the upper board from the lower board).
    • To remove the white wire connector on the bottom board, use a spudger underneath the white plug and pop it out (this disconnects the upper board from the lower board).
  7. Remove the 5 mm round head screw holding the middle piece to the top piece.
    • Remove the 5 mm round head screw holding the middle piece to the top piece.
    • The outermost shell will now separate from the middle structure.
  8. Using the Phillips #1 screwdriver, unscrew the 5 mm black flat head screw that's securing the scroll wheel cage.
    • Using the Phillips #1 screwdriver, unscrew the 5 mm black flat head screw that's securing the scroll wheel cage.
  9. Pinch the cage to release snaps. You can now pull the cage off. Pinch the cage to release snaps. You can now pull the cage off.
    • Pinch the cage to release snaps. You can now pull the cage off.
  10. Remove the screw holding the circuit board down.
    • Remove the screw holding the circuit board down.
    • The board will now pop off easily.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
David
668 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 18-36, Regan Winter 2013 Mitglied von Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
3 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 516
