Zum Hauptinhalt wechseln
Urge Basics Soundbrick Speaker Woofer Replacement
Was du brauchst
  1. Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: Schritt 1, Bild 1 von 3 Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: Schritt 1, Bild 2 von 3 Urge Basics Soundbrick Speaker Woofer Replacement, Speaker Woofer: Schritt 1, Bild 3 von 3
    • Flip the speaker upside down.
    • Unscrew the middle screw with a Philips #1 screwdriver.
  2. Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 2, Bild 1 von 2 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 2, Bild 2 von 2
    • Peel off the two gray tabs to expose the four inner Philips #1 screws.
  3. Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 3, Bild 1 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 3, Bild 2 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 3, Bild 3 von 3
    • Unscrew all four screws with a Philips #1 screwdriver.
    • The screws are deep and can be difficult to take out.
  4. Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 4, Bild 1 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 4, Bild 2 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 4, Bild 3 von 3
    • Flip the speaker so that the ports are facing up.
    • Unfold the speaker's cover away from the body.
  5. Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 5, Bild 1 von 2 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 5, Bild 2 von 2
    • Remove the two Phillips #1 screws found on each side of the battery compartment.
    • Removal of battery compartment is necessary to prevent electric shock when replacing the woofer.
  6. Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 6, Bild 1 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 6, Bild 2 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 6, Bild 3 von 3
    • Disconnect the battery connectors attached to the circuit board by unplugging them.
  7. Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 7, Bild 1 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 7, Bild 2 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 7, Bild 3 von 3
    • Disconnect the ribbon cable from the battery by carefully pulling it out.
    • Remove the battery compartment.
  8. Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 8, Bild 1 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 8, Bild 2 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 8, Bild 3 von 3
    • Disconnect the adjacent connector from the main circuit board.
  9. Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 9, Bild 1 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 9, Bild 2 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 9, Bild 3 von 3
    • Disconnect the woofer's two connectors from the main circuit board.
  10. Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 10, Bild 1 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 10, Bild 2 von 3 Urge Basics Soundbrick Speaker Woofer Replacement: Schritt 10, Bild 3 von 3
    • Remove the two Phillips #1 screws keeping each woofer in place.
    • Carefully remove the woofers and replace them with new ones.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Itzel Urueta
125 Reputation
1 Anleitung geschrieben
UC Davis, Team S2-G4, Cole Spring 2017 Mitglied von UC Davis, Team S2-G4, Cole Spring 2017
UCD-COLE-S17S2G4
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 889
