Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This is a step-by-step procedure for replacing an E-cigarette coil that is placed in a tank. The tank holds the E-cigarette flavors (juice). The coil brand is Uwell Crown III and the coil ohms are 4.0 ohms.
  1. Remove the tank from the E-cigarette by gently unscrewing it by hand. Remove the tank from the E-cigarette by gently unscrewing it by hand. Remove the tank from the E-cigarette by gently unscrewing it by hand.
    • Remove the tank from the E-cigarette by gently unscrewing it by hand.
  2. Take-off the upper lid. This is necessary as the lid will go through cleaning process. Take-off the upper lid. This is necessary as the lid will go through cleaning process. Take-off the upper lid. This is necessary as the lid will go through cleaning process.
    • Take-off the upper lid. This is necessary as the lid will go through cleaning process.
  3. Remove the bottom lid from the tank. The bottom lid holds the coil inside the tank. By removing the bottom lid, you are able to take out the coil. Remove the bottom lid from the tank. The bottom lid holds the coil inside the tank. By removing the bottom lid, you are able to take out the coil.
    • Remove the bottom lid from the tank. The bottom lid holds the coil inside the tank. By removing the bottom lid, you are able to take out the coil.
  4. Remove the old coil from the tank. In the third picture, you can see the difference between the new coil on the left and the burnt coil on the right. In the third picture, you can see the difference between the new coil on the left and the burnt coil on the right.
    • Remove the old coil from the tank.
    • In the third picture, you can see the difference between the new coil on the left and the burnt coil on the right.
  5. This is the tank and both upper and bottom lids after the disassembly process.
    • This is the tank and both upper and bottom lids after the disassembly process.
  6. To clean the tank and the lids, you need to submerge them in a glass of water for approximately 3-4 minutes to make sure they are cleaned properly. To clean the tank and the lids, you need to submerge them in a glass of water for approximately 3-4 minutes to make sure they are cleaned properly.
    • To clean the tank and the lids, you need to submerge them in a glass of water for approximately 3-4 minutes to make sure they are cleaned properly.
  7. After the tank and the lids are cleaned, use the towel to dry them as much possible before the next step. After the tank and the lids are cleaned, use the towel to dry them as much possible before the next step. After the tank and the lids are cleaned, use the towel to dry them as much possible before the next step.
    • After the tank and the lids are cleaned, use the towel to dry them as much possible before the next step.
  8. Use the hair dryer with medium heat to make sure no water drops exist.
    • Use the hair dryer with medium heat to make sure no water drops exist.
    • Any water drops might affect the function of the coil which will result into a flavor change.
  9. Place the new coil inside the tank. Make sure the coil is stable and not moving. Using the two lids, close the tank from both sides and make sure that the lids are perfectly sealed. Using the two lids, close the tank from both sides and make sure that the lids are perfectly sealed.
    • Place the new coil inside the tank. Make sure the coil is stable and not moving.
    • Using the two lids, close the tank from both sides and make sure that the lids are perfectly sealed.
Abschluss
To reassemble your device, follow step 2 in reverse order.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Washington State, Team S1-G1, Hope Summer 2018 Mitglied von Washington State, Team S1-G1, Hope Summer 2018
WSU-HOPE-SU18S1G1
3 Mitglieder
1 Anleitung geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 3
Letzten 7 Tage: 7
Letzten 30 Tage: 39
Insgesamt: 3,922
