Zum Hauptinhalt wechseln
VENSTAR Taco Disassembly
Was du brauchst
  1. VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: Schritt 1, Bild 1 von 3 VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: Schritt 1, Bild 2 von 3 VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: Schritt 1, Bild 3 von 3
    • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
    • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
  2. VENSTAR Taco Disassembly: Schritt 2, Bild 1 von 2 VENSTAR Taco Disassembly: Schritt 2, Bild 2 von 2
    • Repeat the previous step on the opposite side to remove the other outer casing.
  3. VENSTAR Taco Disassembly: Schritt 3, Bild 1 von 2 VENSTAR Taco Disassembly: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Phillips #0 Screwdriver
    $5.49
    Kaufen
    • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
    • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
  4. VENSTAR Taco Disassembly: Schritt 4, Bild 1 von 2 VENSTAR Taco Disassembly: Schritt 4, Bild 2 von 2
    • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
  5. VENSTAR Taco Disassembly: Schritt 5, Bild 1 von 2 VENSTAR Taco Disassembly: Schritt 5, Bild 2 von 2
    • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 422
