Einleitung
Here we will be removing the small michrophone in the back of the taco. This task requires removing the logic board before it may be reached.
Was du brauchst
Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
Repeat the previous step on the opposite side to remove the other outer casing.
In diesem Schritt verwendetes Werkzeug:Phillips #0 Screwdriver$5.49
Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
Undo the connector of the flat white ribbon between the switches and the logic board.
Below the logic board, the small black microphone is resting within the case.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
