Einleitung
In this guide, you will learn step-by-step instructions on how to replace the broken shell of a VHS tape when it is too broken to work correctly in a VHS player. In doing this repair, you will be able to salvage the tape so that it can be digitized or continue to be watched. No special skills are needed for this repair, with a screwdriver being the only tool used. It is recommended that you cut or rip off any labels on the sides of the tape before beginning, so that it will be easier to take the top half of the shell off.
Was du brauchst
Hold down on the white lever.
While holding down, carefully take out the reel on the right.
Take out the left reel and set them both aside, with the tape still wrapped inside and connecting them.
Get the replacement shell and unscrew the 5 marked 3mm (21/32 in length) #1 Phillips screws with the screwdriver.
Place the right reel into the replacement shell, making sure the tape goes in-between metal and plastic circular pieces here.
Place the left reel into the replacement shell, making sure the tape goes in-between metal circular piece and the plastic triangular piece pictured.
2 Kommentare zur Anleitung
Hello. Does anyone know where to buy new cassette parts including the shell, hub and all the internals? I'm looking to move tape from a broken shell to a new one so that I can play it and digitize it. Thank you.
The best option is just to purchase a random movie you don't care about from a thrift store and use that for parts.
Chloe N. -
