Einleitung
Does your device not respond when buttons are pressed? Do only a few buttons seem to function correctly? This guide will walk through the steps required to replace the buttons.
Was du brauchst
To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
Remove the rear panel screws using a Phillips #2 screwdriver.
Two 21.6mm (Long)
One 9.8mm (Short)
Five 13.8mm (Medium)
Eine weitere Person hat diese Anleitung absolviert.
