Einleitung
Is the sound for your device distorted, crackling or nonexistent? This guide may be a solution to fix your problem.
Was du brauchst
To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
Remove the rear panel screws using a Phillips #2 screwdriver.
Two 21.6mm (Long)
One 9.8mm (Short)
Five 13.8mm (Medium)
Use a Phillips #0 screwdriver to unscrew the two 6.0 mm screws on the speaker.
2 Kommentare
Where to buy the replacement speaker
Where can you buy the replacement speaker please. I live in Sydney Australia
