Zum Hauptinhalt wechseln
VTech Baby's Learning Laptop Mode Switch Replacement
Was du brauchst
  1. VTech Baby's Learning Laptop Mode Switch Replacement, Battery and Rear Panel: Schritt 1, Bild 1 von 1
    • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
    • A coin can also be used to loosen the screw.
  2. VTech Baby's Learning Laptop Mode Switch Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery door.
    • Take out the batteries.
  3. VTech Baby's Learning Laptop Mode Switch Replacement: Schritt 3, Bild 1 von 1
    • Remove the rear panel screws using a Phillips #2 screwdriver.
    • Two 21.6mm (Long)
    • One 9.8mm (Short)
    • Five 13.8mm (Medium)
  4. VTech Baby's Learning Laptop Mode Switch Replacement: Schritt 4, Bild 1 von 2 VTech Baby's Learning Laptop Mode Switch Replacement: Schritt 4, Bild 2 von 2
    • Gently pull up on the rear panel.
    • Be careful not to pull on the wire connections.
    • Rest the laptop open on the table.
  5. VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: Schritt 5, Bild 1 von 2 VTech Baby's Learning Laptop Mode Switch Replacement, Mode Switch: Schritt 5, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the three 7.3mm screws.
  6. VTech Baby's Learning Laptop Mode Switch Replacement: Schritt 6, Bild 1 von 3 VTech Baby's Learning Laptop Mode Switch Replacement: Schritt 6, Bild 2 von 3 VTech Baby's Learning Laptop Mode Switch Replacement: Schritt 6, Bild 3 von 3
    • Once the screws have been removed from the board, use a plastic opening tool to gently pry up the board and expose the mode switch assembly underneath.
    • Lay the board down gently and out of the way.
    • Take care not to damage any of the wires or the board itself.
  7. VTech Baby's Learning Laptop Mode Switch Replacement: Schritt 7, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove the seven screws securing the mode switch assembly to the device.
    • Five 7.3mm
    • Two 6.0mm
  8. VTech Baby's Learning Laptop Mode Switch Replacement: Schritt 8, Bild 1 von 1
    • Once the screws have been removed, the mode switch assembly can be removed easily.
    • Take care not to misplace the spring indicated in the picture.
    • You need this spring to find a matching replacement if it is in anyway damaged.
Abschluss
USF Tampa, Team 12-2, Blackwell Fall 2015 Mitglied von USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 4
Insgesamt: 504
