Einleitung
During this guide, the back of the phone will be taken off by using the spudger. Then the circuit board will be detached by unscrewing two screws.
Was du brauchst
Push down on the battery cover in the direction of the arrow located on the back of the phone.
Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
Use the plastic opening tool and spudger to pry the back side of the phone off.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Thanks! Had to clean honey out if the speaker. Should Note the plastic quality is soft and can mark easily.
