Einleitung
During this guide, the back of the phone will need to be taken off to access the speaker and wires. You will need to use the tweezers to remove the metal “U” shaped clip holding the speaker to the back cover.
Was du brauchst
Push down on the battery cover in the direction of the arrow located on the back of the phone.
Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
Use the plastic opening tool and spudger to pry the back side of the phone off.
Locate the metal shaped U clip holding the speaker on. Pull up and towards the top of the phone with the flat head tweezers.
Heat up solder joint on the circuit board where the speaker wires are connected.
Refer to How To Solder and Desolder Connections Wie man Lötverbindungen herstellt und entlötet
2 Kommentare
Where can I buy the speaker for the phone?
