Einleitung
This guide will show how to replace the battery in the VTech InnoTab Max.
Was du brauchst
Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
Here you can see the back cover has been fully removed and you can now access the front cover.
To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
10 Kommentare
Where can we purchase a replacement battery
Where can we buy a replacement battery
Nice of you to show this, but I can not find that particular battery anywhere. Not even the China website.
Let us know where we can get the battery.
