Einleitung
This guide will show any user how to replace the cover on a VTech InnoTab Max.
Was du brauchst
Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
Here you can see the back cover has been fully removed and you can now access the front cover.
To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
