Einleitung
The battery may sometimes malfunction in a device and may need to be replaced for the device to function again.
Was du brauchst
Using a plastic opening tool, gently pry off the circular plating over the camera lens.
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
Unscrew the (4) 2.5mm Phillips head screws from the third layer of plating using a #0 screwdriver.
Turn the camera around and gently remove the plating that surrounds the LCD screen by grasping it with your fingers and pulling away from the device.
Use the plastic opening tool to lift the LCD screen, including the purple casing and set it aside, revealing the motherboard and connector ribbon.
Use the soldering iron to unsolder the battery wires connected to the motherboard by reheating the existing solder.
Gently lift the battery away from the motherboard using a plastic opening tool.
8 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Where will get new batteries for same.
Where does one buy a replacement battery? And what type of battery is it?
