Einleitung
Exercise caution when removing the camera lens's connecting ribbon , as any excessive pulling can damage the motherboard. Otherwise, the camera lens is one of the quickest replacements, as it only requires light unscrewing, prying, and re-applying hot glue.
Was du brauchst
Using a plastic opening tool, gently pry off the circular plating over the camera lens.
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
Use a #0 screwdriver to remove the two 2.5mm Phillips head screws located on the second layer of plating.
Remove the second layer of plating previously held down by the screws by gripping it with your fingers and pulling upward.
Unscrew the (4) 2.5mm Phillips head screws from the third layer of plating using a #0 screwdriver.
Turn the camera around and gently remove the plating that surrounds the LCD screen by grasping it with your fingers and pulling away from the device.
Use the plastic opening tool to lift the LCD screen, including the purple casing and set it aside, revealing the motherboard and connector ribbon.
Heat the iOpener tool, then press the iOpener tool onto the connectors to heat the glue on the connector ribbon.
Gently peel the connector ribbon being held down by the heated glue until it is completely removed.
When connecting the new camera lense, press the new connector ribbon to the original ribbon's position.
Eine weitere Person hat diese Anleitung absolviert.
