Zum Hauptinhalt wechseln
VTech Kidizoom Camera Connect Front Case Replacement
Was du brauchst
  1. VTech Kidizoom Camera Connect Front Case Replacement, Front Case: Schritt 1, Bild 1 von 2 VTech Kidizoom Camera Connect Front Case Replacement, Front Case: Schritt 1, Bild 2 von 2
    • Remove batteries and SD card before beginning disassembly!
    • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
  2. VTech Kidizoom Camera Connect Front Case Replacement: Schritt 2, Bild 1 von 2 VTech Kidizoom Camera Connect Front Case Replacement: Schritt 2, Bild 2 von 2
    • Remove all four (11mm) screws with the Philips #0 screwdriver.
  3. VTech Kidizoom Camera Connect Front Case Replacement: Schritt 3, Bild 1 von 3 VTech Kidizoom Camera Connect Front Case Replacement: Schritt 3, Bild 2 von 3 VTech Kidizoom Camera Connect Front Case Replacement: Schritt 3, Bild 3 von 3
    • Remove the two battery cartridges located on the underside of the camera.
    • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
  4. VTech Kidizoom Camera Connect Front Case Replacement: Schritt 4, Bild 1 von 1
    • Beware of the two black viewfinder lens falling out as you pry open the device!
    • The device should now be open and ready for further repair and/or replacement parts.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 6-4, Eyestone Spring 2016 Mitglied von USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 40
Insgesamt: 4,616
