Zum Hauptinhalt wechseln
VTech Kidizoom Smartwatch DX2 Battery Replacement
Was du brauchst
  1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: Schritt 1, Bild 1 von 2 VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: Schritt 1, Bild 2 von 2
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Battery Replacement: Schritt 2, Bild 1 von 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: Schritt 2, Bild 2 von 2
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Battery Replacement: Schritt 3, Bild 1 von 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: Schritt 3, Bild 2 von 2
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Battery Replacement: Schritt 4, Bild 1 von 3 VTech Kidizoom Smartwatch DX2 Battery Replacement: Schritt 4, Bild 2 von 3 VTech Kidizoom Smartwatch DX2 Battery Replacement: Schritt 4, Bild 3 von 3
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Battery Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Battery Replacement: Schritt 6, Bild 1 von 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: Schritt 6, Bild 2 von 2
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Battery Replacement: Schritt 7, Bild 1 von 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: Schritt 7, Bild 2 von 2
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
  8. VTech Kidizoom Smartwatch DX2 Battery Replacement, Battery: Schritt 8, Bild 1 von 1
    • Carefully pry the battery off of the circuit board using the plastic opening tool.
  9. VTech Kidizoom Smartwatch DX2 Battery Replacement: Schritt 9, Bild 1 von 1
    • De-solder the wires connecting the battery to the circuit board.
    • Remove the battery.
Abschluss
UMass Dartmouth, Team S3-G5, Peak Fall 2018 Mitglied von UMass Dartmouth, Team S3-G5, Peak Fall 2018
UMASSD-PEAK-F18S3G5
4 Mitglieder
7 Anleitungen geschrieben
4 Kommentare
Hey guys, My VTech watch is plugged in but once I turn it on it does but then shows a dead battery. I actually didn’t play with it for a while and I left it dead battery.
Gabriel Baker - Antwort
So I might try this trick and see if it works.
Sometime i’ll try it
when I have the right tools
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 30
Letzte 30 Tage: 104
Insgesamt: 9,140
