Einleitung
If one of the cameras on your device is broken, cracked, or damaged in any way, the following guide will show you how to replace the camera.
Was du brauchst
Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
After removing the backplate, lift the master switch up from the circuit board.
Carefully remove the speaker from the case without disconnecting it from the motherboard.
Turn the motherboard so the battery is on the bottom and locate the two clips holding the cameras in place.
Carefully lift the clips and slide the cameras out.
