Zum Hauptinhalt wechseln
VTech Kidizoom Smartwatch DX2 Faceplate Replacement
Was du brauchst
  1. VTech Kidizoom Smartwatch DX2 Faceplate Replacement, Faceplate: Schritt 1, Bild 1 von 1
    • In order to remove the faceplate you must start by placing the watch screen upwards.
  2. VTech Kidizoom Smartwatch DX2 Faceplate Replacement: Schritt 2, Bild 1 von 1
    • Use iFixit’s opening tool, another similar tool, or simply use your fingernail to gently pry open the faceplate away from the screen starting from an edge.
    • You may hear a popping sound, but this is normal.
  3. VTech Kidizoom Smartwatch DX2 Faceplate Replacement: Schritt 3, Bild 1 von 1
    • Once successful, pull the remaining faceplate off from the watch.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S3-G5, Peak Fall 2018 Mitglied von UMass Dartmouth, Team S3-G5, Peak Fall 2018
UMASSD-PEAK-F18S3G5
4 Mitglieder
7 Anleitungen geschrieben
4 Kommentare
Where can I find a faceplate?
Sammi Schummer - Antwort
Where can you buy a replacement face plate?
Natalie - Antwort
This doesn't remove the faceplate, just the decorative bezel around the screen. I'm looking for disassembly instructions to open up the screen as my son wore his I to the pool (immediately after being told not to! Kids…)
Jack Wesselo - Antwort
Where can I get a replacement faceplate please
Steph Crowe - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 21
Insgesamt: 2,537
