Zum Hauptinhalt wechseln
VTech Kidizoom Smartwatch DX2 Motherboard Replacement
Was du brauchst
  1. VTech Kidizoom Smartwatch DX2 Motherboard Replacement, Master Switch: Schritt 1, Bild 1 von 2 VTech Kidizoom Smartwatch DX2 Motherboard Replacement, Master Switch: Schritt 1, Bild 2 von 2
    • Begin by flipping the watch over with its back facing upwards.
  2. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: Schritt 2, Bild 1 von 2 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
  3. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: Schritt 3, Bild 1 von 2 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Gently lift the backplate up to remove it.
  4. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: Schritt 4, Bild 1 von 3 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: Schritt 4, Bild 2 von 3 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: Schritt 4, Bild 3 von 3
    • After removing the backplate, lift the master switch up from the circuit board.
  5. VTech Kidizoom Smartwatch DX2 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
  6. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: Schritt 6, Bild 1 von 2 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Carefully remove the speaker from the case without disconnecting it from the motherboard.
  7. VTech Kidizoom Smartwatch DX2 Motherboard Replacement: Schritt 7, Bild 1 von 2 VTech Kidizoom Smartwatch DX2 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Using the tweezers, carefully lift the bar holding the connection to the screen.
    • Remove the motherboard from the device.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S3-G5, Peak Fall 2018 Mitglied von UMass Dartmouth, Team S3-G5, Peak Fall 2018
UMASSD-PEAK-F18S3G5
4 Mitglieder
7 Anleitungen geschrieben
2 Kommentare
This shows how to take the motherboard out, but how to I get a replacement motherboard? I don’t see anywhere that I can purchase one…
ltiede12 - Antwort
I’m interested in the components on the motherboard. What type of SOC does it use, what operating system, etc…
Asher Kobin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 14
Letzte 30 Tage: 42
Insgesamt: 3,519
