Einleitung
In order to remove the screen or the battery, the main board will have to be removed first. Follow this guide to set you on your way.
Was du brauchst
Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
After removing the backplate, lift the master switch up from the circuit board.
Carefully remove the speaker from the case without disconnecting it from the motherboard.
Using the tweezers, carefully lift the bar holding the connection to the screen.
Remove the motherboard from the device.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
I’m interested in the components on the motherboard. What type of SOC does it use, what operating system, etc…
