Zum Hauptinhalt wechseln
VTech Kidizoom Smartwatch DX2 Wristband Replacement
Was du brauchst
  1. VTech Kidizoom Smartwatch DX2 Wristband Replacement, Wristband: Schritt 1, Bild 1 von 1
    • Begin by placing the watch on its side.
  2. VTech Kidizoom Smartwatch DX2 Wristband Replacement: Schritt 2, Bild 1 von 1
    • Next, use the flat end of the spudger to wedge between the small-headed pin (located on the band closest to the watch) to pull the pin up through the other side.
  3. VTech Kidizoom Smartwatch DX2 Wristband Replacement: Schritt 3, Bild 1 von 1
    • Pull the pin out, however not fully, feeling slight resistance is normal.
  4. VTech Kidizoom Smartwatch DX2 Wristband Replacement: Schritt 4, Bild 1 von 1
    • Finally, pull the wristband off. Repeat on the opposite side of the watch if necessary.
Abschluss
Sydney
344 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S3-G5, Peak Fall 2018 Mitglied von UMass Dartmouth, Team S3-G5, Peak Fall 2018
UMASSD-PEAK-F18S3G5
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
My Vtech DX2 had a split pin. One side of the pin was the long side and the other very very short. So look out for that. Thanks for this tutorial, was very helpful.
Ryan Laurel - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 51
Insgesamt: 7,254
