Zum Hauptinhalt wechseln
VTech Learning Tunes Karaoke Power Button Replacement
Was du brauchst
  1. VTech Learning Tunes Karaoke Power Button Replacement, Power Button: Schritt 1, Bild 1 von 1
    • To remove the battery door, loosen the 4mm screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw
  2. VTech Learning Tunes Karaoke Power Button Replacement: Schritt 2, Bild 1 von 2 VTech Learning Tunes Karaoke Power Button Replacement: Schritt 2, Bild 2 von 2
    • Remove the battery door and take out the batteries.
  3. VTech Learning Tunes Karaoke Power Button Replacement: Schritt 3, Bild 1 von 1
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
  4. VTech Learning Tunes Karaoke Power Button Replacement: Schritt 4, Bild 1 von 2 VTech Learning Tunes Karaoke Power Button Replacement: Schritt 4, Bild 2 von 2
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
  5. VTech Learning Tunes Karaoke Power Button Replacement: Schritt 5, Bild 1 von 1
    • Remove four 7.9 mm screws from the mode selector and voice selector trays.
  6. VTech Learning Tunes Karaoke Power Button Replacement: Schritt 6, Bild 1 von 1
    • Remove the two 5.6 mm screws from the power button board.
  7. VTech Learning Tunes Karaoke Power Button Replacement: Schritt 7, Bild 1 von 1
    • Carefully move the power button board out of the way.
    • From here you can replace the button.
Abschluss
USF Tampa, Team 7-2, Cheng Spring 2016 Mitglied von USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 545
