Zum Hauptinhalt wechseln
VTech MobiGo Touch Learning System Buttons Replacement
Was du brauchst
    1. VTech MobiGo Touch Learning System Buttons Replacement, Case: Schritt 1, Bild 1 von 1
      • Remove the battery covers and the four batteries.
      Frag FixBot
      Kommentar hinzufügen
    2. VTech MobiGo Touch Learning System Buttons Replacement: Schritt 2, Bild 1 von 2 VTech MobiGo Touch Learning System Buttons Replacement: Schritt 2, Bild 2 von 2
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      Frag FixBot
    3. VTech MobiGo Touch Learning System Buttons Replacement: Schritt 3, Bild 1 von 2 VTech MobiGo Touch Learning System Buttons Replacement: Schritt 3, Bild 2 von 2
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      Frag FixBot
    1. VTech MobiGo Touch Learning System Buttons Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: Schritt 4, Bild 1 von 1
      • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
      Frag FixBot
    2. VTech MobiGo Touch Learning System Buttons Replacement: Schritt 5, Bild 1 von 1
      • Remove the three "L" shaped brackets and the spring.
      Frag FixBot
    3. VTech MobiGo Touch Learning System Buttons Replacement: Schritt 6, Bild 1 von 1
      • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
      Frag FixBot
    4. VTech MobiGo Touch Learning System Buttons Replacement: Schritt 7, Bild 1 von 1
      • Separate the front and back of the case.
      • Use a plastic opening tool if necessary.
      Frag FixBot
    1. VTech MobiGo Touch Learning System Buttons Replacement, Buttons: Schritt 8, Bild 1 von 1
      • Remove 6 (3.8 mm Philips J0) screws holding the buttons in.
      Frag FixBot
    2. VTech MobiGo Touch Learning System Buttons Replacement: Schritt 9, Bild 1 von 2 VTech MobiGo Touch Learning System Buttons Replacement: Schritt 9, Bild 2 von 2
      • From here you can remove and replace the buttons.
      Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 8-3, Eyestone Fall 2015 Mitglied von USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Mitglieder
23 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 19
Insgesamt: 1,588
