Zum Hauptinhalt wechseln
VTech MobiGo Touch Learning System Screen Replacement
Was du brauchst
  1. VTech MobiGo Touch Learning System Screen Replacement, Case: Schritt 1, Bild 1 von 1
    • Remove the battery covers and the four batteries.
  2. VTech MobiGo Touch Learning System Screen Replacement: Schritt 2, Bild 1 von 2 VTech MobiGo Touch Learning System Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. VTech MobiGo Touch Learning System Screen Replacement: Schritt 3, Bild 1 von 2 VTech MobiGo Touch Learning System Screen Replacement: Schritt 3, Bild 2 von 2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. VTech MobiGo Touch Learning System Screen Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: Schritt 4, Bild 1 von 1
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
  5. VTech MobiGo Touch Learning System Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the three "L" shaped brackets and the spring.
  6. VTech MobiGo Touch Learning System Screen Replacement: Schritt 6, Bild 1 von 1
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
  7. VTech MobiGo Touch Learning System Screen Replacement: Schritt 7, Bild 1 von 1
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
  8. VTech MobiGo Touch Learning System Screen Replacement, Screen: Schritt 8, Bild 1 von 1
    • Remove the 4 (3.4 mm Philips J0) screws holding the screen in
  9. VTech MobiGo Touch Learning System Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove the black tape
  10. VTech MobiGo Touch Learning System Screen Replacement: Schritt 10, Bild 1 von 1
    • Remove the circuit board from the back of the screen.
    • The circuit board has double sided tape on the back side holding it to the screen.
  11. VTech MobiGo Touch Learning System Screen Replacement: Schritt 11, Bild 1 von 1
    • Peel the ribbon wire off of the circuit board. Now the screen should be free to remove.
  12. VTech MobiGo Touch Learning System Screen Replacement: Schritt 12, Bild 1 von 1
    • Resolder the new screens ribbon cable on the the circuit board.
    • Always be careful when soldering.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Daniel Kresge
385 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 8-3, Eyestone Fall 2015 Mitglied von USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Mitglieder
17 Anleitungen geschrieben
1 Kommentar zur Anleitung
mine i droped a rock on so i don’t get it
Jesse Eagan - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 956
