Einleitung
Follow this repair guide to find out how to replace the speaker with a functional one.
Was du brauchst
Using the Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws at the bottom of the monitor.
Remove the two 5.0 mm Phillips #00 screws at the top of the device which holds the antenna at the top of the motherboard.
This will allow the removal of the silver handle.
Use the plastic spudger to push the two white plastic tabs, at the bottom of the device, up to release the metal retaining clip.
