Zum Hauptinhalt wechseln
VTech Safe And Sound DM221 Speaker Replacement
Was du brauchst
  1. VTech Safe And Sound DM221 Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Remove the battery cover.
  2. VTech Safe And Sound DM221 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Unplug the battery from its connector and remove.
  3. VTech Safe And Sound DM221 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Using the Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws at the bottom of the monitor.
  4. VTech Safe And Sound DM221 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Separate the back half of the device from the front using the metal spudger.
  5. VTech Safe And Sound DM221 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Remove the two 5.0 mm Phillips #00 screws at the top of the device which holds the antenna at the top of the motherboard.
    • This will allow the removal of the silver handle.
  6. VTech Safe And Sound DM221 Speaker Replacement: Schritt 6, Bild 1 von 1
    • Remove the “TALK” button to get access to remove the motherboard.
  7. VTech Safe And Sound DM221 Speaker Replacement: Schritt 7, Bild 1 von 1
    • Push down on the antenna, located on the top of the motherboard.
  8. VTech Safe And Sound DM221 Speaker Replacement: Schritt 8, Bild 1 von 1
    • Gently remove the motherboard away from the monitor.
    • Be careful not to disconnect the red wire.
  9. VTech Safe And Sound DM221 Speaker Replacement: Schritt 9, Bild 1 von 1
    • Use the plastic spudger to push the two white plastic tabs, at the bottom of the device, up to release the metal retaining clip.
Abschluss
Krystal
600 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 1-5, Leahy Fall 2015 Mitglied von USF Tampa, Team 1-5, Leahy Fall 2015
USFT-LEAHY-F15S1G5
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 329
