Zum Hauptinhalt wechseln
VTech Touch and Swipe Baby Phone Battery Replacement
Was du brauchst
  1. VTech Touch and Swipe Baby Phone Battery Replacement, Battery: Schritt 1, Bild 1 von 2 VTech Touch and Swipe Baby Phone Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. VTech Touch and Swipe Baby Phone Battery Replacement: Schritt 2, Bild 1 von 3 VTech Touch and Swipe Baby Phone Battery Replacement: Schritt 2, Bild 2 von 3 VTech Touch and Swipe Baby Phone Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. VTech Touch and Swipe Baby Phone Battery Replacement: Schritt 3, Bild 1 von 3 VTech Touch and Swipe Baby Phone Battery Replacement: Schritt 3, Bild 2 von 3 VTech Touch and Swipe Baby Phone Battery Replacement: Schritt 3, Bild 3 von 3
    • When reassembling, align the notch on the battery panel with the slot on the phone.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Zack Drawdy
231 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 2-4, Sullivan Fall 2015 Mitglied von USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
3 Mitglieder
12 Anleitungen geschrieben
2 Kommentare
Seems this device is VERY sensitive to low batteries. An issue I assumed was the power switch (randomly turning off) was actually batteries. Also hilarious this has an iFixit page.
Chris Uthe - Antwort
Thank you! Changing the batteries fixed the loop issue
Jessica Dorado - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 13
Letzte 30 Tage: 22
Insgesamt: 1,091
