Zum Hauptinhalt wechseln
VTech VM3254 Camera Speaker Replacement
Was du brauchst
  1. VTech VM3254 Camera Speaker Replacement, Camera Circuit Board: Schritt 1, Bild 1 von 3 VTech VM3254 Camera Speaker Replacement, Camera Circuit Board: Schritt 1, Bild 2 von 3 VTech VM3254 Camera Speaker Replacement, Camera Circuit Board: Schritt 1, Bild 3 von 3
    • Remove the two 8 mm Phillips #00 screws from the back of the device.
    • Use the Jimmy tool to open the case.
    • You may need to use an opening pick to hold it open.
    • Remove the face from the case.
  2. VTech VM3254 Camera Speaker Replacement: Schritt 2, Bild 1 von 2 VTech VM3254 Camera Speaker Replacement: Schritt 2, Bild 2 von 2
    • Remove the three 8 mm Phillips #00 screws from the board.
    • Gently remove the board from the case.
    • Be careful, there are wires connecting the board to the case that could be damaged.
  3. VTech VM3254 Camera Speaker Replacement, Camera Speaker: Schritt 3, Bild 1 von 3 VTech VM3254 Camera Speaker Replacement, Camera Speaker: Schritt 3, Bild 2 von 3 VTech VM3254 Camera Speaker Replacement, Camera Speaker: Schritt 3, Bild 3 von 3
    • Unscrew and remove the two 7 mm Phillips #0 screws that secure the speaker.
    • Remove the speaker.
    • Desolder the speakers cords from the motherboard.
Abschluss
Utah Tech University, Team 1-2, McMurrin Spring 2023 Mitglied von Utah Tech University, Team 1-2, McMurrin Spring 2023
UTAHTECH-MCMURRIN-S23S1G2
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 9
Letzte 30 Tage: 19
Insgesamt: 179
