Zum Hauptinhalt wechseln
VTech Write and Learn Creative Center Magnetic Screen Replacement
Was du brauchst
  1. VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: Schritt 1, Bild 1 von 3 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: Schritt 1, Bild 2 von 3 VTech Write and Learn Creative Center Magnetic Screen Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
  2. VTech Write and Learn Creative Center Magnetic Screen Replacement, Slider: Schritt 2, Bild 1 von 1
    • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
    • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
  3. VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: Schritt 3, Bild 1 von 2 VTech Write and Learn Creative Center Magnetic Screen Replacement, Magnetic Screen: Schritt 3, Bild 2 von 2
    • Remove the four 5mm PH 0 Phillips screws with 7mm heads holding the screen to the front of the case.
  4. VTech Write and Learn Creative Center Magnetic Screen Replacement: Schritt 4, Bild 1 von 1
    • Gently push the edges of the screen to remove it from the front case.
Abschluss
UMass Dartmouth, Team 1-2, Miles Spring 2016 Mitglied von UMass Dartmouth, Team 1-2, Miles Spring 2016
UMASSD-MILES-S16S1G2
3 Mitglieder
12 Anleitungen geschrieben
2 Kommentare
Thank you for this! Do you have suggestions on how to fix the magnetic screen or get a replacement? I emailed the manufacturer (B. Toys for mine) and unfortunately they replied, “​We replace the full toy only, and do not offer the internal parts as replacements.“ But I don’t want all the rest of the plastic - I just want the magnets on the screen to properly appear and disappear. Instead, its like the magnetic powder floats so it’s constantly grey rather than clear or magnetized.
Katie - Antwort
Hello I got the same issue i dont know how to fix ot of you mine is not even an year old but still get that grey screen plz help n let me know how to get rid of it Thankyou
wings_latif -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 20
Insgesamt: 1,379
