Einleitung
Follow this guide to replace the head strap on a Valve Index VR headset.
Power off and unplug your Index before you begin your repair.
Werkzeuge
Ersatzteile
Twist the eye tube relief knob clockwise to fully extend it.
Insert an opening pick between the eye relief knob and the head strap.
Gently pry with the opening pick while pulling the eye relief knob off until it is removed.
Insert the flat end of a spudger in between the bottom of the head strap clip and the head strap padding.
Pry up on the head strap clip until it is unclipped from the head strap.
Use your hand to gently pull the face gasket straight off of the headset.
Use your fingers to pull the tether cable straight up off of the head strap cable guide.
Pull the tether cable straight back out of the headset.
Insert your T5 Torx screwdriver into the hole on the face gasket bezel to remove the captive screw securing the left side of the head strap.
Skip to step 12.
Use a T5 Torx screwdriver to remove the four 6.0 mm screws securing the face gasket bezel to the headset.
Grab the left edge of the face gasket bezel with your hand and slide it off of the headset.
Repeat the previous step for the right side of the face gasket bezel.
Remove the face gasket bezel.
Use a T5 Torx screwdriver to remove the two 6.6 mm screws underneath the eye relief knob.
Use a T5 Torx screwdriver to loosen the screw securing the left side of the head strap to the headset.
Slide the head strap band out from the headset.
The head strap is now fully removed.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Valve Index Answers community for help.
Ein weiterer Nutzer hat diese Anleitung absolviert.
