Zum Hauptinhalt wechseln
Vanmoof No 3 Replacement Mudguards
  1. Vanmoof No 3  Replacement Mudguards, Get the Mudguards: Schritt 1, Bild 1 von 1
    • Make sure you get 2 mudguards, one set of stays that are straight for the rear, and a second that have a bend. Also make sure you have the two rear connection pieces.
  2. Vanmoof No 3  Replacement Mudguards, The problem: Schritt 2, Bild 1 von 1
    • You need to cut both sides of the mudguard so it can fit between the chain stays, and drill a new hole to attach to the bottom of the frame.
  3. Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: Schritt 3, Bild 1 von 3 Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: Schritt 3, Bild 2 von 3 Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: Schritt 3, Bild 3 von 3
    • The rear mudguard will need to be cut at the front.
    • First cut at parallel to the bottom about 16mm long
    • Second cut is 7mm in from the rounded edge
  4. Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: Schritt 4, Bild 1 von 3 Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: Schritt 4, Bild 2 von 3 Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: Schritt 4, Bild 3 von 3
    • Bend the edges over so you make a rounded lip
  5. Vanmoof No 3  Replacement Mudguards, Drill the new hole: Schritt 5, Bild 1 von 1
    • Drill the frame attachment hole
    • Bolt to the frame
Abschluss
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 34
Insgesamt: 1,217
