Zum Hauptinhalt wechseln
VanMoof No 3 Light Battery Replacement
Was du brauchst
  1. VanMoof No 3 Light Battery Replacement, Battery: Schritt 1, Bild 1 von 3 VanMoof No 3 Light Battery Replacement, Battery: Schritt 1, Bild 2 von 3 VanMoof No 3 Light Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Buy two, "2/3" AAA NiCad rechargeable batteries. Better still get four so you can replace the batteries in both lights.
    • Get the batteries with solder tabs
  2. VanMoof No 3 Light Battery Replacement, Disassemble the light: Schritt 2, Bild 1 von 1
    • Nothing to it really - just remove the 2 cross point screws
  3. VanMoof No 3 Light Battery Replacement, Remove the battery: Schritt 3, Bild 1 von 2 VanMoof No 3 Light Battery Replacement, Remove the battery: Schritt 3, Bild 2 von 2
    • Use a flat blade screw driver to pull the battery from the adhesive tape.
    • Remove the heat shrink plastic joining the batteries
  4. VanMoof No 3 Light Battery Replacement, Unsolder the battery: Schritt 4, Bild 1 von 2 VanMoof No 3 Light Battery Replacement, Unsolder the battery: Schritt 4, Bild 2 von 2
    • Unsolder the wires
  5. VanMoof No 3 Light Battery Replacement, Solder the new battery: Schritt 5, Bild 1 von 3 VanMoof No 3 Light Battery Replacement, Solder the new battery: Schritt 5, Bild 2 von 3 VanMoof No 3 Light Battery Replacement, Solder the new battery: Schritt 5, Bild 3 von 3
    • Tin the battery tabs
    • Join together with tape. You'll remove this later. Both +ve ends are joined
    • The red wire goes on the end of the battery that has a ridge.
  6. VanMoof No 3 Light Battery Replacement, Join the batteries: Schritt 6, Bild 1 von 1
    • Remove the temporary tape
    • Fold the tabs inwards
    • Cover with 2 pieces of insulation tape. The wires will come out of the middle, between the pieces of tape
  7. VanMoof No 3 Light Battery Replacement, Reassemble: Schritt 7, Bild 1 von 3 VanMoof No 3 Light Battery Replacement, Reassemble: Schritt 7, Bild 2 von 3 VanMoof No 3 Light Battery Replacement, Reassemble: Schritt 7, Bild 3 von 3
    • Put the small black cup back on the switch. The dome goes outwards.
    • Put the outer switch in the lense. It goes in the smaller hole
    • The black body will be flush when it's pushed together.
  8. VanMoof No 3 Light Battery Replacement, Reassemble 2: Schritt 8, Bild 1 von 2 VanMoof No 3 Light Battery Replacement, Reassemble 2: Schritt 8, Bild 2 von 2
    • Test the light turns on
    • Screw the back plate to the lense.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Martin Hampton
1.308 Reputation
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 44
Letzte 30 Tage: 151
Insgesamt: 7,774
