Einleitung
This guide is for replacing a dying or faulty battery in your Micro Cruz Tablet. This replacement is not overly difficult and can be completed in less than an hour. You will need to be careful when opening the device up because the stress can cause some damages.
Was du brauchst
Insert a plastic opening device into the small crack separating the screen and the back of the device.
After the back of the device is separated, remove the back and you can now access the battery.
The battery is connected to the motherboard where the picture indicates.
To remove the battery, you must first detach the battery wire connecting it from the motherboard. To do this, simply gently, but firmly, pull it out of the motherboard connector.
Simply pry the battery out of the device at this point. The battery may be held in place by adhesive glue and require a nylon spudger or plastic opening tool to help pry it out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
