Was du brauchst
Using one of the plastic opening tools, separate the plastic back from the tablet in one spot.
Gently work the tool around the diameter of the tablet until the back pops completely off.
Locate the camera as illustrated. Remove the 3 black screws at the top of the tablet.
Gently pull back the yellow piece so that the camera may be accessed.
Use the tweezers to pull back the black latch on the motherboard that holds the camera.
Finally, use the tweezers to remove the camera from the motherboard.
