Zum Hauptinhalt wechseln
Velocity Micro Cruz T301 Speakers Replacement
Was du brauchst
  1. Velocity Micro Cruz T301 Speakers Replacement, Speakers: Schritt 1, Bild 1 von 1
    • Insert an opening tool in the SD port, with the edge pointing towards the rear panel.
    • Use the opening tool to pry the back plate up.
  2. Velocity Micro Cruz T301 Speakers Replacement: Schritt 2, Bild 1 von 1
    • Insert a second opening tool into the space created by the first opening tool.
  3. Velocity Micro Cruz T301 Speakers Replacement: Schritt 3, Bild 1 von 1
    • Remove the first opening tool.
  4. Velocity Micro Cruz T301 Speakers Replacement: Schritt 4, Bild 1 von 2 Velocity Micro Cruz T301 Speakers Replacement: Schritt 4, Bild 2 von 2
    • Slide the opening tool across the back plate to disconnect the clips joining the plate to the tablet.
  5. Velocity Micro Cruz T301 Speakers Replacement: Schritt 5, Bild 1 von 1
    • Remove the four screws in the metal plate covering the battery using a Phillips #0 screwdriver.
  6. Velocity Micro Cruz T301 Speakers Replacement: Schritt 6, Bild 1 von 1
    • Using a plastic spudger to remove the battery connector.
    • Failure to follow this step may result in an electric shock.
  7. Velocity Micro Cruz T301 Speakers Replacement: Schritt 7, Bild 1 von 1
    • Remove the battery with a spudger.
    • The photos in this guide use a metal spudger. Do not use a metal spudger as it can damage the device or conduct electricity causing a shock.
  8. Velocity Micro Cruz T301 Speakers Replacement: Schritt 8, Bild 1 von 1
    • Remove the twelve screws in the cover with a Phillips #0 screwdriver.
  9. Velocity Micro Cruz T301 Speakers Replacement: Schritt 9, Bild 1 von 1
    • Place a spudger between the tablet base and the screen.
    • Again this photo shows the use of a metal spudger. The use of a metal spudger can cause damage to the device and can lead to an electric shock.
  10. Velocity Micro Cruz T301 Speakers Replacement: Schritt 10, Bild 1 von 1
    • Move the spudger around the face to release the clips attached to the tablet base.
  11. Velocity Micro Cruz T301 Speakers Replacement: Schritt 11, Bild 1 von 1
    • Locate the speaker on the motherboard. Use the plastic spudger to disconnect the speaker from the connection port.
    • Plug the new speaker into the port, then use the plastic spudger to gently push it in.
Abschluss
USF Tampa, Team 1-6, Cagle Fall 2016 Mitglied von USF Tampa, Team 1-6, Cagle Fall 2016
USFT-CAGLE-F16S1G6
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 107
