Zum Hauptinhalt wechseln
Velocity NoteMagix M10 A82 DDR RAM Replacement
Was du brauchst
  1. Velocity NoteMagix M10 A82 DDR RAM Replacement, Battery: Schritt 1, Bild 1 von 2 Velocity NoteMagix M10 A82 DDR RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 DDR RAM Replacement: Schritt 2, Bild 1 von 2 Velocity NoteMagix M10 A82 DDR RAM Replacement: Schritt 2, Bild 2 von 2
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 DDR RAM Replacement, RAM: Schritt 3, Bild 1 von 2 Velocity NoteMagix M10 A82 DDR RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • Locate the DDR panel and unscrew the two 3.65mm Phillips #1 screws holding it in place.
    • Use the spudger to lift the DDR panel off.
  4. Velocity NoteMagix M10 A82 DDR RAM Replacement: Schritt 4, Bild 1 von 3 Velocity NoteMagix M10 A82 DDR RAM Replacement: Schritt 4, Bild 2 von 3 Velocity NoteMagix M10 A82 DDR RAM Replacement: Schritt 4, Bild 3 von 3
    • Push in the tabs on the sides that contain the RAM.
    • Gently raise the RAM up to a 45 degree angle and gently pull the RAM towards you.
Abschluss
Sam Middleton
401 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 14-9, Forte Fall 2013 Mitglied von Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 364
